show ip dhcp-snooping binding interface
Displays DHCP Snooping binding table information based on interface type.
Syntax
Command Parameters
gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Displays DHCP Snooping binding table information for the specified port number.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
Default
None
Command Mode
User EXEC
